StarTech.com 4 port PCI 1394a FireWire Adapter Card - 3 Exter...
StarTech.com 4 port PCI 1394a FireWire Adapter Card - 3 External 1 Internal
£17.62
45 in stock
Delivery:
Standard: 1-3 working days
Key features
  • An internal connector allows for the easy connection of internal FireWire peripherals
  • High speed data transfer rates of up to 400 Mbits/sec
  • Hot swap capabilities allows you to connect or disconnect devices without turning off your computer
  • Type: FireWire adapter
  • Compatibility: Mac, PC
  • Interface: PCI
  • Stock Status: In Stock
Product codes
Add 4 FireWire ports to a desktop computer through a PCI slot. This 4 Port (3 External/1 Internal) PCI 1394 FireWire Adapter Card lets you connect iPods, MP3 players, portable drives, digital camcorders and more to your desktop computer.
The FireWire adapter card supports hot-swapping, so you'll be able to plug, unplug, and swap your FireWire peripherals with ease.
Plus, the adapter provides both standard profile and low profile/half-height brackets for adapting to slimline or small form factor system applications.
If you require digital video editing software, StarTech.com offers a complete FireWire kit with our PCI1394 4 card. This software is compatible with Windows operating systems only.
Product Description StarTech.com 4 port PCI 1394a FireWire Adapter Card - 3 External 1 Internal - FireWire adapter - 3 ports
Device Type FireWire adapter
Form Factor Plug-in card
Interface (Bus) Type PCI
Ports Qty 3 ports
Data Link Protocol Firewire
Data Transfer Rate 400 Mbps
System Requirements Microsoft Windows 2000, Apple MacOS 8.6 or later, Microsoft Windows 98/ME, Microsoft Windows XP, Windows 10 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 port PC...
£17.62
