StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Contr...
StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering
£69.09
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Leverage SSD performance and standard HDD capacity with HyperDuo technology
  • Maximize system capability with SATA III connection speeds
  • Fit any standard or low profile chassis with included brackets
  • Compatibility: Mac, PC
  • Stock Status: In Stock
Product codes
Add 4 Internal SATA III (6Gbps) ports to a computer through a PCI Express x2 slot. The PEXSAT34RH 4-Port PCI Express 2.0 SATA Controller Card with HyperDuo adds 4 AHCI SATA III ports to a computer through a PCIe slot (x2), delivering multiple internal 6Gbps connections for high-performance hard drives and Solid State Drives (SSDs).
Featuring HyperDuo technology, the SATA card offers SSD auto-tiering which lets you balance the performance advantages of SSD storage with the cost-effectiveness and large capacity of standard hard drives. By combining SSD and HDD drives into a single volume (up to 3 SSD + 1 HDD), HyperDuo discreetly works in the background to identify and move frequently accessed files to the faster SSD drive(s) for improved data throughput - up to 80% of SSD performance! (Note: The HyperDuo automatic storage tiering feature is compatible with computers that use a BIOS.)
The PCIe SATA controller card supports Port Multiplier (PM), enabling multiple SATA drives to be connected to one port over a single cable, for a total of 7 drives (Up to 4 drives through PM on one port, and a single drive to the remaining 3 ports). Plus, the SATA controller card offers an effective hardware RAID solution, with native RAID (0, 1, 1+0) support.
Product Description StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering - PCIe SATA 3 Controller Adapter (PEXSAT34RH) - storage controller (RAID) - SATA 6Gb/s - PCIe 2.0 x2
Device Type Storage controller (RAID) - plug-in card - low profile
Bus Type PCIe 2.0 x2
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Supported Devices Disk array (RAID)
Channel Qty 4
RAID Level RAID 0, RAID 1, RAID 10, JBOD
System Requirements Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X Lion 10.7, Windows 8 (32/64 bits), Apple MacOS X 10.8, Windows 10 (32/64 bits)
Dimensions (WxDxH) 12 cm x 7 cm x 2 cm
Weight 50 g
Designed For P/N: ST521PMINT
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port PC...
£69.09
