Add 4 Internal SATA III (6Gbps) ports to a computer through a PCI Express x2 slot. The PEXSAT34RH 4-Port PCI Express 2.0 SATA Controller Card with HyperDuo adds 4 AHCI SATA III ports to a computer through a PCIe slot (x2), delivering multiple internal 6Gbps connections for high-performance hard drives and Solid State Drives (SSDs).
Featuring HyperDuo technology, the SATA card offers SSD auto-tiering which lets you balance the performance advantages of SSD storage with the cost-effectiveness and large capacity of standard hard drives. By combining SSD and HDD drives into a single volume (up to 3 SSD + 1 HDD), HyperDuo discreetly works in the background to identify and move frequently accessed files to the faster SSD drive(s) for improved data throughput - up to 80% of SSD performance! (Note: The HyperDuo automatic storage tiering feature is compatible with computers that use a BIOS.)
The PCIe SATA controller card supports Port Multiplier (PM), enabling multiple SATA drives to be connected to one port over a single cable, for a total of 7 drives (Up to 4 drives through PM on one port, and a single drive to the remaining 3 ports). Plus, the SATA controller card offers an effective hardware RAID solution, with native RAID (0, 1, 1+0) support.
Product Description | StarTech.com 4 Port PCI Express SATA III RAID Card w/ HyperDuo SSD Tiering - storage controller (RAID) - SATA 6Gb/s - PCIe 2.0 x2 | Device Type | Storage controller (RAID) - plug-in card - low profile | Bus Type | PCIe 2.0 x2 | Interface | SATA 6Gb/s | Data Transfer Rate | 6 Gbit/s | Supported Devices | Disk array (RAID) | Channel Qty | 4 | RAID Level | RAID 0, RAID 1, RAID 10, JBOD | System Requirements | Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 (32/64 bits), Apple MacOS X 10.8, Windows 10 (32/64 bits) | Dimensions (WxDxH) | 12 cm x 7 cm x 2 cm | Weight | 50 g | Manufacturer Warranty | 2-year warranty |
General | |
Host Bus | PCIe 2.0 x2 |
Storage Controller | |
Channel Qty | 4 |
Processor | Marvell 88SE9230 |
Expansion / Connectivity | |
Interfaces | 4 x SATA 6Gb/s - SATA (internal) |
Miscellaneous | |
Included Accessories | Low-profile bracket |
Compliant Standards | FCC, RoHS |
Software / System Requirements | |
OS Required | Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 (32/64 bits), Apple MacOS X 10.8, Windows 10 (32/64 bits) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 12 cm |
Depth | 7 cm |
Height | 2 cm |
Weight | 50 g |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
