StarTech.com 4 Port PCI Express Low Profile High Speed USB Card
£30.66
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backward compatible with USB version 1.1
  • Compatible with PCI Express x1, x2, x4, x8, and x16 slots
  • Compliant with PCI Express 1.1 specs
  • Drivers are WHQL certified
  • Easy plug and play installation
  • Fully compatible with USB OHCI specifications
  • Type: USB adapter
  • Compatibility: PC
  • Interface: PCI Express x1
  • Stock Status: In Stock
Product codes
The PEXUSB4DP is a low profile 4 port USB card designed for versatility and performance.
Providing simple system expansion for added peripheral connections, this PCI Express USB card adds 3 external USB 2.0 slots and 1 internal USB 2.0 slot, with support for high speed USB 2.0 data transfer rates of up to 480 Mbps, and includes WHQL certified drivers and easy plug and play installation.
Capable of adapting to virtually any PC case form factor, the low profile USB card includes a standard profile bracket for installation in full form factor cases.
Product Description StarTech.com 4 Port PCI Express Low Profile High Speed USB Card - PCIe USB 2.0 Card - PCI-E USB 2.0 Card (PEXUSB4DP) - USB adapter - 4 ports
Device Type USB adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express x1
PCI Specification Revision PCIe 1.1
Dimensions (WxDxH) 9 cm x 2 cm x 8 cm
Weight 46 g
Ports Qty 4 ports
Data Link Protocol USB, USB 2.0
Data Transfer Rate 480 Mbps
Compliant Standards USB 1.1, USB 2.0
System Requirements Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple MacOS X 10.6 - 10.10, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux 3.5.x - 4.11.x LTS versions only
Designed For P/N: ST4200MINI2
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port PC...
£30.66
