StarTech.com 4 Port PCI Express PCIe Serial Combo Card - 2 x...
StarTech.com 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485
£111.03
23 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Includes both low profile/half-height and full profile brackets to ensure fitment into a broad range of system form factors
  • The included breakout cable saves expense as an all-in-one solution, and allows the addition of multiple serial ports through a single PCI Express slot
  • This single PCI Express combo card is compatible with any serial device protocol (RS232, RS422, and RS485), allowing for communication with multiple devices over mixed protocols
  • Type: Serial adapter
  • Compatibility: PC
  • Interface: PCI Express x1
  • Stock Status: In Stock
Product codes
Add two RS232, and two RS422/485 serial ports to your PC through a PCI-Express expansion slot. The PEX4S232485 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485 lets you add two RS232, and two RS422/485 serial ports to your PC through a PCI-Express expansion slot.
This PCI express serial card is a single card solution that is compatible with nearly any serial communication protocol, supporting RS-232, RS-422, RS-485 2-wire or RS-485 4-wire operating modes.
A flexible solution for adding serial ports to full-sized, or small form factor systems, the 4-port serial card includes both low and full profile brackets while the included breakout cable helps to avoid cluttered connections.
Product Description StarTech.com 4 Port PCI Express PCIe Serial Combo Card - serial adapter - 4 ports
Device Type Serial adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express x1
Dimensions (WxDxH) 2 cm x 7 cm x 12.5 cm
Weight 67.4 g
Ports Qty 4 ports
Data Link Protocol RS-232, RS-422, RS-485
System Requirements Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port PC...
£111.03
