StarTech.com 4 Port PCI RS232 Serial Adapter Card with 16550...
StarTech.com 4 Port PCI RS232 Serial Adapter Card with 16550 UART
£41.42
Delivery:
Standard: 1-3 working days
  • Type: Serial adapter
  • Compatibility: PC
  • Interface: PCI
  • Stock Status: In Stock
Product codes
Add 4 high-speed RS-232 serial ports to your PC through a PCI expansion slot. The PCI4S550N 4-port PCI Serial card turns an available PCI slot into four RS232 serial ports - a cost-effective solution for connecting any new or old serial peripheral, with support for data transfer rates of up to 115Kbps.
The PCI Serial card is a perfect solution for connecting serial modems, POS devices, PDAs, digital cameras, printers, ISDN terminal adapters and more, to your system without having to upgrade your peripheral devices for compatibility with newer standards (e.g. USB).
Saving time and hassle, the Serial PCI card is plug-and-play ready, and can be installed in minutes, supporting Windows 7, Server 2008 R2, Vista, XP, ME, 2000, 98, 95, NT4, 3.1, DOS and Linux operating systems. Plus, the serial card offers IRQ sharing to help ensure stability and consistent performance, guaranteeing convenient, hassle-free connections.
Product Description StarTech.com 4-Port PCI Serial Card with 16550 UART - PCI RS232 Serial Adapter Card (PCI4S550N) - serial adapter - PCI - RS-232 x 4
Device Type Serial adapter
Form Factor Plug-in card
Interface (Bus) Type PCI
Ports RS-232 x 4
Dimensions (WxDxH) 11.9 cm x 7.4 cm
Data Link Protocol RS-232
Data Transfer Rate 921 Kbps
System Requirements Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port PC...
£41.42
