StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with...
StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA / SP4 Power
£59.02
19 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Increased data transfer rates (up to 1.3 Gbps PCI bus limit) with USB 3.0 compatible devices
  • Suitable for installation in standard-sized and Small Form Factor computers
  • Supports bus-powered USB 3.0 devices
  • Type: USB adapter
  • Compatibility: PC
  • Interface: PCI-X
  • Stock Status: In Stock
Product codes
Add 4 SuperSpeed USB 3.0 ports to a computer through a PCI slot. The PCIUSB3S4 4-Port PCI to USB 3.0 Card enables legacy PCI slots to support the SuperSpeed USB 3.0 standard, which is capable of data transfer rates up to 5 Gbps. Using USB 3.0 devices with this card will increase data transfer rates with up to 1.3 Gbps of available bandwidth (PCI bus limit) - more than doubling performance compared to a USB 2.0 connection.
This versatile USB 3.0 adapter includes an optional SATA power connector which allows each USB port to deliver up to 900mA of power to connected USB 3.0 devices - suitable for even the most power hungry devices.
A perfect solution for older PCI-based systems or computers with only PCI expansion slots remaining, the card allows those systems to stay relevant and up-to-date with the latest USB technology. The card is also backward compatible with USB 2.0 and 1.x devices, so it will not only work with any future USB 3.0 devices, but will also support older devices.
Product Description StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA/SP4 Power - Quad Port PCI USB 3 Controller Card (PCIUSB3S4) - USB adapter - PCI-X - USB 3.0 x 4
Device Type USB adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI-X
Bus Voltage Universal (3.3 V & 5.0 V)
Ports USB 3.0 x 4
Dimensions (WxDxH) 2 cm x 13.3 cm x 6.5 cm
Weight 80 g
Data Link Protocol USB, USB 2.0, USB 3.0
Data Transfer Rate 5 Gbps
Processor NEC uPD720202
Compliant Standards USB 1.1, USB 2.0, USB 3.0
Colour Red
System Requirements Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Designed For P/N: HBS304A24A, S3510BMU33, S3510SMU33, UNI251BMU33, USB221SS
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port PC...
£59.02
