StarTech.com 4-Port PCIe Gigabit NIC
£137.86
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Wired / Wireless: Wired
  • Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Compatibility: PC, Unix
  • Type: Network adapter
  • Stock Status: In Stock
Product codes
Add four Gigabit Ethernet ports to a client, server or workstation through one PCI Express slot. Now you can add four separate Gigabit network ports to your client, server or workstation through just one PCI Express slot, to provide connectivity to multiple networks without draining your budget.
This 4-port network card delivers powerful connectivity for your business, corporate or government office environment, with support for high-performance, 4-channel networking and a maximum throughput of up to 1000 Mbps in each direction (2000 Mbps total). The network adapter card features the Realtek RTL8111G chipset, which is designed to deliver the performance and enhanced capabilities you need for reliable network connections to your server or computer.
This versatile quad-port network card is ideal for many business applications requiring upgrades to servers or workstations, adding feature-rich Gigabit networking with four independent ports. Compatible with a broad range of operating systems, this cost-effective PCIe Gigabit NIC is suitable for many SMB and Enterprise applications such as virtualized environments that require multiple NICs.
Product Description StarTech.com 4-Port PCIe Gigabit Network Adapter Card - network adapter
Device Type Network adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express
Ports Gigabit Ethernet x 4
Dimensions (WxDxH) 1.8 cm x 13.8 cm x 12 cm
Weight 100 g
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Data Link Protocol 10Mb LAN, 100Mb LAN, GigE
Processor RTL8111G - Realtek Semiconductor
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
Colour Yellow
System Requirements Microsoft Windows Server 2003, Microsoft Windows Server 2012, Microsoft Windows XP/ 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4-Port PC...
£137.86
