StarTech.com 4 Port PCIe USB 3.0 Card
£28.69
41 in stock
Delivery:
Standard: 1-3 working days
  • Type: USB adapter
  • Compatibility: PC
  • Interface: PCI Express 2.0 x1
  • Stock Status: In Stock
Product codes
Add four USB 3.0 ports - three external ports and one internal port - to your computer. Here's a cost-effective solution for adding USB 3.0 connectivity to your computer. This 4-port PCIe USB 3.0 card gives you three external ports and one internal port, for the ultimate connection flexibility.
With three external USB 3.0 ports you can connect more devices to your computer. The card provides easy access to commonly-used peripherals such as your tablet and external hard drive. It also features an internal USB port that lets you connect a device such as a flash drive inside your computer case, providing added security and convenience.
USB 3.0 gives you fast access to your files with data transfer rates up to 5 Gbps. Plus it's backward compatible with USB 2.0 and 1.x devices, which eliminates the cost and aggravation of upgrading your existing devices.
Setup is a breeze with native operating system support. The USB 3.0 adapter card automatically installs in Windows.
For convenient installation, this PCI Express USB 3.0 card features a dual-profile design that can be installed in almost any type of computer. It comes equipped with a standard profile bracket and also includes a low-profile bracket for installation in small form-factor/half-height systems.
This high-performance USB 3.0 card is enhanced with UASP support, which can perform ~70% faster read speed and ~40% faster write speed over traditional USB 3.0, when paired with.
Product Description StarTech.com 4 Port PCI Express USB 3.0 Card - 3 External and 1 Internal - Native OS Support in Windows 8 and 7 - Standard and Low-Profile (PEXUSB3S42) - USB adapter
Device Type USB adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express 2.0 x1
Ports USB 3.0 x 4
Dimensions (WxDxH) 1.9 cm x 8.7 cm x 12 cm
Weight 59 g
Data Link Protocol USB, USB 2.0, USB 3.0
Data Transfer Rate 5 Gbps
Processor VL805
Compliant Standards USB 1.1, USB 2.0, USB 3.0
System Requirements Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Linux 2.6.31 or later, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
Designed For P/N: CFASTRWU3, ST1030USBM, ST43004UA, ST4300MINI, TB31PCIEX16
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port PC...
£28.69
