StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Buil...
StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable
GREAT FOR ADDING EXTRA PORTS TO YOUR ULTRABOOK, TABLET OR MACBOOK
£18.28
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Four SuperSpeed USB 3.0 ports, with data transfer rates up to 5 Gbps
  • Travel friendly, with a portable, lightweight design and a built-in cable that offers flexible desk placement options
  • Perfect for your device
  • Backward compatible with USB 2.0 and USB 1.0/1.1 specifications and devices
  • Plug-and-Play and Hot-Swap compatible
  • Type: USB Hub
  • Interface: SuperSpeed USB 3.0
  • Ports: 4
  • Form Factor: External
  • Stock Status: In Stock
Product codes
Add four USB 3.0 ports to your laptop or Ultrabook using this slim, portable hub with an extended-length cable. This 4-Port Portable USB 3.0 Hub with Built-in Cable turns a single USB 3.0 port into four, letting you connect more of your devices to your computer.
The hub features a built-in, 25 cm (10 in) cable that is longer than what most traditional hubs offer. The extended-length cable gives you the flexibility to place the hub and your devices exactly where you want them, and it ensures the hub can connect to your laptop or tablet regardless of where the laptop's USB 3.0 port is located.
This portable USB 3.0 hub is great for adding extra ports to your laptop, tablet, Microsoft Surface Pro 4, Surface Book, and other Microsoft Surface products.
With an integrated cable you have more flexibility to place the hub on your desk as desired. Plus, the hub is USB-powered for easy transport when you travel.
This USB hub offers a block-style design with ports placed across the top surface of the hub. With upright port access your connected devices (for example, flash drives and mouse and keyboard wireless receivers) take up less desk space.
Alternatively, you can lay the hub on its side for easy cable connections to devices like external hard drivers or printers.
With its compact design, you can easily position the USB 3.0 (also known as USB 3.1 Gen 1) hub on your desk or workspace to make your USB devices more accessible. There's also ample space between the USB 3.0 ports, so it's easy to plug and unplug the devices you use the most.
The USB 3.0 hub is natively supported in virtually all operating systems, which makes for an easy setup with no driver installation required. And because it's backward compatible, you can connect both new and legacy USB devices (for example USB 2.0 peripherals).
Product Description StarTech.com 4-Port USB 3.0 Hub with Built-in Cable - SuperSpeed Laptop USB Hub - Portable USB Splitter - Mini USB Hub (ST4300PBU3) - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 4 x SuperSpeed USB 3.0
Features USB powered
Compliant Standards USB 1.1, USB 2.0, USB 3.0
Dimensions (WxDxH) 3 cm x 13.7 cm x 2.2 cm
Weight 80 g
Colour Black
System Requirements Microsoft Windows 2000, Apple MacOS X 10.0 or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port Po...
£18.28
