StarTech.com 4 Port RS232 Mini PCI Express Serial Card with 1...
StarTech.com 4 Port RS232 Mini PCI Express Serial Card with 16650 UART
£79.33
13 in stock
Delivery:
Standard: 1-3 working days
  • Type: Serial adapter
  • Compatibility: PC
  • Interface: Mini PCI Express
  • Stock Status: In Stock
Product codes
Add Four RS232 Serial Ports to an Embedded System through a mini PCI Express Slot.
The MPEX4S952 4-Port RS232 Mini PCI Express Serial Card (16650 UART) turns a mini-PCIe slot into four RS232 (DB9) serial ports with data rates up to 921.6 Kbps - a cost-saving solution for adding serial support to embedded systems missing the functionality.
A native PCIe single-chip design enables you to take advantage of full PCI Express bus capability, by providing improved speed and reliability while reducing the load applied to the CPU by as much as 48% over conventional "bridge chip" serial cards.
Product Description StarTech.com 4 Port RS232 Mini PCI Express Serial Card w/ 16650 UART (MPEX4S552) - serial adapter
Device Type Serial adapter
Form Factor Plug-in card
Interface (Bus) Type Mini PCI Express
PCI Specification Revision PCIe 1.1
Ports RS-232 x 4
Dimensions (WxDxH) 1 cm x 6 cm x 3 cm
Weight 150 g
Data Link Protocol RS-232
Data Transfer Rate 921.6 Kbps
Processor MosChip Semiconductor MCS9904CV-AA
System Requirements Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Linux Kernel 2.6.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port RS...
£79.33
