StarTech.com 4 Port RS232 PCI Serial Card Adapter with Power...
StarTech.com 4 Port RS232 PCI Serial Card Adapter with Power Output
£83.38
Delivery:
Key features
  • Includes both low profile/half-height and full profile brackets to ensure fitment into a broad range of system form factors
  • Selectable 5/12V power output on one of four different pins provides the flexibility needed to connect nearly any powered serial device
  • The included breakout cable saves expense as an all-in-one solution, and allows the addition of multiple RS232 serial ports through a single PCI slot
Product codes
Add 4 RS232 serial ports with 5V or 12V selectable power output to your computer, through a PCI slot. The PCI4S954PW 4-Port PCI Serial Card (with power output) turns a PCI slot into 4 RS232 (DB9) serial connections and enables compatible devices to draw power from the serial ports.
Suitable for many RS232-powered serial applications, this PCI serial card offers a selectable 5V or 12V power option, capable of power output using pin 1, 4, 8 or 9, which enables you to configure the card to suit the requirements of your powered RS232 devices.
A flexible solution for adding serial ports to full-sized, or small form factor systems, the 4-port serial card includes both low and full profile brackets while the included breakout cable helps to avoid cluttered connections.
Product Description StarTech.com 4 Port RS232 PCI Serial Card Adapter with Power Output - serial adapter - PCI - RS-232 x 4
Device Type Serial adapter
Form Factor Plug-in card
Interface (Bus) Type PCI
PCI Specification Revision PCI 3.0
Ports RS-232 x 4
Dimensions (WxDxH) 1.9 cm x 5.7 cm x 12 cm
Weight 95 g
Data Link Protocol RS-232
Data Transfer Rate 460.8 Kbps
Processor OXUPCI954
System Requirements Microsoft Windows Server 2003, Linux 2.4.x, Linux 2.6.x, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7, Windows 10 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port RS...
£83.38
