StarTech.com 4 Port USB 2.0 Extender over Cat5 or Cat6 - Up t...
StarTech.com 4 Port USB 2.0 Extender over Cat5 or Cat6 - Up to 330 ft (100m)
£389.95
Delivery:
Product codes
Extend four USB 2.0 connections up to 330ft away from the computer over Cat5 or Cat6 cable. The USB2004EXT2 4-Port USB Extender lets you extend USB 2.0 devices over Cat 5 or better Ethernet cable at distances of up to 330ft (100m). An included power adapter at remote end provides up to 500 mA of power per port, letting you access and power up to four USB 2.0 devices at remote locations away from the host computer system.
This USB extender provides support for data transfer rates of up to 480 Mbps, is Plug-and-Play and hot-swap compatible, and is also backwards compatible with USB 1.x devices.
This versatile USB extender offers a fast, easy, and flexible solution for business or industrial applications with durable metal housing, and an included surface-mounting bracket kit.
Product Description StarTech.com 4-Port USB Extender - Up to 330 ft (100m) USB 2.0 over Cat5/Cat6 Extender - 480 Mbps USB Over Ethernet Extender (USB2004EXT2) - USB extender - USB, USB 2.0
Device Type USB extender
Ports Qty 4
Form Factor External
Data Transfer Rate 480 Mbps
Data Link Protocol USB, USB 2.0
Max Transfer Distance 100 m
Designed For P/N: 35FCREADBK3
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port US...
£389.95
