We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Extend four USB 2.0 connections up to 330ft away from the computer over Cat5 or Cat6 cable. The USB2004EXT2 4-Port USB Extender lets you extend USB 2.0 devices over Cat 5 or better Ethernet cable at distances of up to 330ft (100m). An included power adapter at remote end provides up to 500 mA of power per port, letting you access and power up to four USB 2.0 devices at remote locations away from the host computer system.
This USB extender provides support for data transfer rates of up to 480 Mbps, is Plug-and-Play and hot-swap compatible, and is also backwards compatible with USB 1.x devices.
This versatile USB extender offers a fast, easy, and flexible solution for business or industrial applications with durable metal housing, and an included surface-mounting bracket kit.
Product Description | StarTech.com Newer version is USB2004EXT2NA - USB Over Ethernet Extender - 4 Port - Cat5 or Cat6 - Up to 330' - USB Over CAT5 Extender (USB2004EXT2) - USB extender - USB, USB 2.0 | Device Type | USB extender | Ports Qty | 4 | Form Factor | External | Data Transfer Rate | 480 Mbps | Data Link Protocol | USB, USB 2.0 | Max Transfer Distance | 100 m | Manufacturer Warranty | 2-year warranty | Designed For | P/N: 35FCREADBK3 |
