StarTech.com 4 Port USB 3.0 Hub USB-C to 4x USB-A
£30.46
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Type: Docking station
  • Interface: SuperSpeed USB 3.0
  • Ports: 4
  • Form Factor: External
Product codes
Turn your laptop's USB Type-C port into four USB Type-A ports (5Gbps) using this bus-powered hub. Here's a must-have accessory if you have a USB-C equipped computer but need more USB-A ports. This portable USB 3.0 hub expands your laptop or desktop connectivity by adding four USB Type-A ports through a single USB Type-C or Thunderbolt 3 port. And, because it's USB bus-powered, you don't need to connect an external power adapter, which makes travel more convenient and workstations less cluttered.
If you're looking to extend the life of your existing USB-A peripheral devices, then this hub is the perfect solution. By converting your computer's USB-C port into four USB-A ports, you can continue to use all of your existing USB 3.0 devices such as flash drives, external hard drives, and printers (USB 3.0 is also known as USB 3.1 Gen 1). Now you can save money by avoiding the added cost and hassle of purchasing new USB-C equipped peripherals.
With its compact and lightweight design, this USB hub is tailored for mobility. You can easily tuck it into your laptop bag when traveling, which makes it easy to expand your connectivity almost anywhere you need to.
Plus, with a small-footprint design the 4-port hub takes up minimal desk space when connected in your work area.
This versatile USB-C hub is bus-powered, which means it draws its power directly from your computer's USB-C port. This means there are fewer cables to carry with you when you travel because it doesn't need an external power adapter.
This USB hub is multi-platform compatible, which means it will work with a wide range of laptops. It also works with a range of operating systems such as Windows, Mac, Linux and Chrome OS . It installs automatically once you connect it to your laptop, so you can be up and running in seconds.
Product Description StarTech.com 4-Port USB-C Hub - Portable USB-C to 4x USB-A Hub - Bus-Powered USB 3.1 Gen 1 Type-C Hub - USB 3.0 Port Expander (HB30C4AB) - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 4 x SuperSpeed USB 3.0
Features USB powered
Compliant Standards USB 1.1, USB 2.0, USB 3.0, USB 3.1
Dimensions (WxDxH) 4.1 cm x 8 cm x 1.5 cm
Weight 35 g
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£30.46
