StarTech.com 4-Port USB 3.0 Hub with On/Off
£33.26
Delivery:
Standard: 1-3 working days
  • Type: USB Hub
  • Interface: USB
  • Ports: 4
  • Form Factor: External
  • Stock Status: In Stock
Product codes
This portable USB 3.0 hub gives you an easy way to add four USB 3.0 Type-A ports to your laptop, with individual power switches to save power. The USB port expander plugs easily into your laptop's USB Type-A port. Plus, it's bus-powered for easy portability.
Use your existing USB 3.0 devices such as flash drives, mouse, keyboard and external hard drives. The 4-port USB 3.0 hub expands your computer's USB Type-A port into four USB 3.0 (Type-A) ports, and it's backward compatible with your older USB 2.0 devices. (USB 3.0 is also known as USB 3.1 Gen 1.)
Each port on the USB 3.0 hub has its own power switch so you can turn off devices when they're not in use. That means you can better manage power consumption for your USB devices, without having to physically disconnect the device or cable.
With its compact, lightweight design, this hub is perfect for portable use. The versatile USB to USB hub is bus-powered, with no need for an external power adapter. You can travel lighter with fewer cables to carry with you.
The 4-Port USB 3.0 hub installs automatically when you connect it to your laptop, so you can be up and running in seconds.
Product Description StarTech.com 4 Port USB 3.0 Hub, USB-A to 4x USB 3.0 Type-A with Individual On/Off Port Switches, SuperSpeed 5Gbps USB 3.1/USB 3.2 Gen 1, USB Bus Powered, Portable, 9.8" Attached Cable - Windows/macOS/Linux (HB30A4AIB) - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 4 x USB 3.1 Gen 1
Features USB powered, on/off switches
Compliant Standards USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 1
Dimensions (WxDxH) 3.49 cm x 8.5 cm x 1.92 cm
Weight 50 g
Colour Black
System Requirements Apple MacOS, Linux, Microsoft Windows
Designed For P/N: HB30C4AIB
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£33.26
