StarTech.com 4 Port USB 3.0 Hub with USB C
£29.98
Delivery:
Product codes
Add four USB 3.0 (5Gbps) ports to your laptop, including three USB Type-A ports, and one USB Type-C port. Here's an easy way to connect a wider range of peripherals to your laptop. This 4-port USB 3.0 hub turns your laptop's USB-A port into three USB-A ports (5Gbps), and one USB-C port. The hub is USB powered, so you can connect devices virtually anywhere you work or go.
Now, you can use your laptop's traditional USB Type-A port to expand your connectivity, and connect your newer USB Type-C devices to your laptop.
This USB 3.0 hub lets you expand your USB connection options using the USB-A port on your computer. (USB 3.0 is also known as USB 3.1 Gen 1.) It offers three USB-A ports and one USB-C port, so you can connect traditional USB devices now, while still being able to connect USB Type-C devices in the future.
It's the ideal way to connect your new USB-C equipped device to your laptop's traditional USB-A port.
With a compact and lightweight design, the USB-powered hub is tailored for mobility. It easily tucks into your carrying case and expands your connectivity when traveling.
This versatile USB hub takes up minimal space on a desk, so you can use it in hot-desk or BYOD (Bring Your Own Device) environments.
The 4-port USB 3.0 hub can help if you need a way to connect your newer USB-C peripherals to your existing laptop. Now you can access your USB-C device while avoiding the cost of purchasing a newer laptop that features a USB Type-C port.
The bus-powered hub installs quickly with no additional drivers or software required, and it's compatible with virtually all operating systems.
Product Description StarTech.com 4 Port USB Hub - USB 3.0 - USB A to 3x USB A and 1x USB C - USB Port Expander - USB Port Hub - Laptop USB Hub (HB30A3A1CFB) - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 4 x SuperSpeed USB 3.0
Features USB powered
Compliant Standards USB 3.0, USB 3.1
Designed For P/N: CFASTRWU3C, SDMSDRWU3AC
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port US...
£29.98
