StarTech.com 4 Port USB 3.0 Hub with USB C
£40.65
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 4 PORT BUS-POWERED USB 3.0 HUB: From a USB Type-A host laptop port, add 3x USB-A and 1x USB-C port; Power up to 4.5W (5V/0.9A) shared with all connected devices; Backward compatible with USB 2.0/1.1
  • SPEEDS UP TO 5Gbps: USB 3.0 SuperSpeed 5Gbps (USB 3.1 Gen 1 / USB 3.2 Gen 1) hub shared with all downstream devices, supports thumb drives, data storage devices, keyboards, mice, web cams, headsets
  • COMPACT & PORTABLE: A lightweight desktop or travel adapter hub with durable plastic housing, 5.5 in (14 cm) attached host cable and small form factor [3 in (75 mm) x 1.6 in (40 mm) x 0.5 in (13 mm)]
  • WIDE OPERATING SYSTEM COMPATIBILITY: OS Independent, driverless setup, supporting major operating systems including Windows, macOS, Linux, iPadOS, Chrome OS and Android
  • STARTECH.COM ADVANTAGE: IT professionals choice for over 30 years; This USB 3.0 Hub is backed for 2-years by StarTech.com, including free 24/5 North America based multi-lingual tech support
  • Type: USB Hub
  • Interface: USB 3.1 Type C
  • Ports: 4
Product codes
Add four USB 3.0 (5Gbps) ports to your laptop, including three USB Type-A ports, and one USB Type-C port. Here's an easy way to connect a wider range of peripherals to your laptop. This 4-port USB 3.0 hub turns your laptop's USB-A port into three USB-A ports (5Gbps), and one USB-C port. The hub is USB powered, so you can connect devices virtually anywhere you work or go.
Now, you can use your laptop's traditional USB Type-A port to expand your connectivity, and connect your newer USB Type-C devices to your laptop.
This USB 3.0 hub lets you expand your USB connection options using the USB-A port on your computer. (USB 3.0 is also known as USB 3.1 Gen 1.) It offers three USB-A ports and one USB-C port, so you can connect traditional USB devices now, while still being able to connect USB Type-C devices in the future.
It's the ideal way to connect your new USB-C equipped device to your laptop's traditional USB-A port.
With a compact and lightweight design, the USB-powered hub is tailored for mobility. It easily tucks into your carrying case and expands your connectivity when traveling.
This versatile USB hub takes up minimal space on a desk, so you can use it in hot-desk or BYOD (Bring Your Own Device) environments.
The 4-port USB 3.0 hub can help if you need a way to connect your newer USB-C peripherals to your existing laptop. Now you can access your USB-C device while avoiding the cost of purchasing a newer laptop that features a USB Type-C port.
The bus-powered hub installs quickly with no additional drivers or software required, and it's compatible with virtually all operating systems.
Product Description StarTech.com 4 Port USB 3.0 Hub, USB Type-A Hub with 1x USB-C & 3x USB-A Ports (SuperSpeed 5Gbps), USB Bus Powered, USB 3.1/USB 3.2 Gen 1 Adapter Hub, Portable USB Hub for Laptop/Desktop - Windows/macOS/Linux (HB30A3A1CFB) - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 4 x SuperSpeed USB 3.0
Features USB powered
Compliant Standards USB 3.0, USB 3.1
Dimensions (WxDxH) 4 cm x 7.5 cm x 1.3 cm
Weight 40 g
Colour Black
Designed For P/N: CFASTRWU3C, SDMSDRWU3AC
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£40.65
