StarTech.com 4-Port USB 3 Hub + 2.4A DCP
£39.76
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fast-charge your iPad, iPhone, and other mobile devices
  • Expand the connectivity of your computer
  • Designed for easy use
Product codes
Add four USB 3.0 ports to your computer, plus fast-charge your mobile device. Here's a must-have accessory for any mobile device user. This compact USB 3.0 hub lets you connect an additional four USB devices to your computer, plus, you can easily fast-charge your mobile device using the hub's dedicated charge port (DCP).
With a 2.4 amp dedicated charge port, the hub makes it fast and easy to charge your smartphone, tablet, and other USB-charged devices, including Android, Apple, and Samsung devices.
The charge and data ports work simultaneously, so you can conveniently fast-charge your mobile device while continuing to use your other USB 3.0 peripherals. The dedicated charge port stays on even if the host computer is turned off, in sleep mode, or disconnected entirely.
Boost your system capabilities by adding four USB 3.0 ports, and enjoy fast data transfer speeds up to 5Gbps. The USB 3.0 (also known as USB 3.1 Gen 1) hub works with your high-bandwidth devices such as external hard drives, high-resolution webcams, flash drives, video cameras, and more.
The 4-port USB 3.0 hub features a small footprint that takes up little space on your desktop. And with ample space between each USB 3.0 port, it's easy to plug and unplug the devices you use the most.
Setup is easy, with no driver installation required, and, for added flexibility the hub is USB-powered or self-powered using the included power adapter.
Note: The included power adapter is required to power the dedicated charge port.
StarTech.com 4-Port USB 3.0 Hub plus Dedicated Charging Port - 1 x 2.4A Port - USB peripheral sharing switch - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
Plastic housing
USB 1.1, USB 2.0, USB 3.0
AC 120/230 V 2 A
6.1 cm x 10.6 cm x 2.5 cm
100 g
Australia, North America, United Kingdom, Europe
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4-Port US...
£39.76
