StarTech.com 4 Port USB A Female Slot Plate Adapter
£7.48
15 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Guaranteed reliability
  • Supports 4 or 5 pin motherboard connections
  • Stock Status: In Stock
Product codes
Add four USB 2.0 Ports to the back of your computer. The USBPLATE4 4 port USB 2.0 slot plate adapter converts the USB pins on your motherboard into four USB-A female ports, enabling you to add USB connections to the back of your PC.
The USBPLATE4 is designed and constructed for maximum durability, to ensure dependable performance.
Check your motherboard's manual for the USB pinout diagram. The USBPLATE wiring scheme is: Red=Power, Green=Signal, White=Signal, Black=Ground.
Product Description StarTech.com 4 Port USB A Female Slot Plate Adapter - USB panel - 4 pin USB Type A (F) (USBPLATE4) - USB panel
Type USB panel
Connector 4 x 4 pin USB Type A - female
Connector (Second End) 2 x 9 pin IDC - female
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port US...
£7.48
