StarTech.com 4 Port USB Adaptor PCI Express USB 3.1 Gen 2 Co...
StarTech.com 4 Port USB Adaptor  PCI Express USB 3.1 Gen 2 Controller Card - 3xA + 1xC
£106.18
Delivery:
Standard: 1-3 working days
Product codes
Add three USB-A ports and one USB-C port, via two host controllers, through a standard PCI Express slot. This USB 3.1 PCIe card lets you add three USB Type-A ports and one USB Type-C port to your computer, through a PCI Express slot. It makes it easy to upgrade your PC to the faster speed of USB 3.1 (10Gbps) so that you can access newer peripherals at twice the speed of traditional USB 3.0 (5Gbps) cards.
When multiple devices are connected, traditional single-bus USB cards share the maximum bandwidth between all ports. By employing two host controller chipsets, shared across two ports rather than four, this 4-port PCIe to USB 3.1 card dedicates up to 10Gbps for each set of two USB ports. It reduces performance bottlenecks and doubles your total available bandwidth to 20Gbps.
With higher data throughput support, the card is ideal for external hard drives, hard drive enclosures, and large external storage devices. It lets you access multiple devices simultaneously for read and write access.
The 4-port USB 3.1controller card adds dual independent channels to your computer and shares 10Gbps of bandwidth between two USB ports.
Each set of two ports shares a combined bandwidth of 10Gbps. If a single device is accessing the channel, the card will provide data transfer rates of up to 10Gbps to the device. If two devices are accessing the channel simultaneously, the 10Gbps of bandwidth will be shared between both devices.
Product Description StarTech.com 4 Port USB 3.1 PCIe Card - 1x USB C & 2x A - 2 10Gbps Channels - USB adapter
Device Type USB adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express 3.0 x4
PCI Specification Revision PCIe 3.0
Ports USB 3.1 Gen 2 x 3 + USB-C 3.1 Gen 2 x 1
Data Link Protocol USB, USB 2.0, USB 3.0, USB 3.1
Data Transfer Rate 10 Gbps
Compliant Standards USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2
System Requirements Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits), Apple macOS 10.13
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port US...
£106.18
