This 4-Port USB-C Hub with optional USB Power Delivery (PD) pass-through, expands the connectivity of a USB-C laptop. This hub features four USB 3.2 Gen 2 (10Gbps) Type-C ports, that support high-bandwidth USB peripherals. Connect the attached USB-C cable to a USB Type-C or Thunderbolt 3/4 port, located on the host computer, to enable the quick connection of up to 4 peripherals. This lightweight USB-C Hub can operate with bus-power. Alternatively, connect a USB-C power adapter (not included) to the designated USB-C PD port for laptop charging.
Product Description | StarTech.com 4-Port USB-C Hub, 4x USB-C Ports, USB 3.1 10Gbps, Portable USB C Hub with 100W Power Delivery Pass-Through, Portable USB Type C Hub w/ 9.8in (25cm) Wrap-Around Cable - USB Expansion Hub (HB31CM4CPD3) - hub - 4 ports | Device Type | Hub - 4 ports | Subtype | USB | Ports | 4 x USB 3.2 Gen 2 | Features | USB powered, plastic housing, USB Pass-Through, Fast Charging Port, USB Power Delivery (up to 100 watt) | Compliant Standards | USB 2.0, USB 3.1 Gen 2, Power Delivery 3.0, USB 3.2 Gen 2, USB 3.2 Gen 1 | Dimensions (WxDxH) | 13.5 cm x 6 cm x 2 cm | Weight | 160 g | Colour | Space grey | System Requirements | Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS | Manufacturer Warranty | 3-year warranty |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Processor | X Realtek Semiconductor RTS5423 / VL160 |
Expansion / Connectivity | |
Interfaces | 4 x USB 3.2 Gen 2 Type C |
Miscellaneous | |
Cables Included | 1 x USB-C cable - 25 cm |
Compliant Standards | Plug and Play, FCC, RoHS, WEEE, RCM |
Software / System Requirements | |
OS Required | Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS |
Dimensions & Weight | |
Width | 13.5 cm |
Depth | 6 cm |
Height | 2 cm |
Weight | 160 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 17 cm |
Shipping Depth | 14.2 cm |
Shipping Height | 3 cm |
Shipping Weight | 175 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 0 - 85% RH (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 80 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
