This USB-C Hub with 100W USB Power Delivery pass-through adds four USB 3.2 Gen 1 (5Gbps) ports (2x USB-A, 2x USB-C) to a USB-C enabled computer. Connect the USB hub to a USB-C port on a laptop, using the built-in 1ft (30cm) USB-C host cable. Charge a host laptop by connecting the host laptop's USB-C power supply to the USB Power Delivery (PD) 3.0 port. Backward compatible with USB 2.0 (480Mbps) devices ensures support for a wide range of modern and legacy USB peripherals (e.g., external storage devices - thumb drives, HDDs/SSDs, HD cameras, mice, keyboards, webcams, and audio headsets). The USB hub supports Wake on USB and is compact in size, facilitating portability when travelling.
Product Description | StarTech.com 4-Port USB-C Hub with 100W Power Delivery Pass-Through Charging, 2x USB-A + 2x USB-C, 5Gbps, USBC Hub w/ 1ft (30cm) Long Cable, Portable Laptop USB Type-C to USB-A/C Hub - USB 3.0 Expansion Hub (5G2A2CPDB-USB-C-HUB) - hub - 4 ports | Device Type | Hub - 4 ports | Subtype | USB | Ports | 2 x USB 3.2 Gen 1 + 2 x USB-C 3.2 Gen 1 | Performance | Data transfer rate: 5 Gbps | Features | USB powered, plastic housing, USB overcurrent detection and prevention, USB Power Delivery (up to 100 watt), USB Power Delivery 3.0 | Compliant Standards | USB 1.1, USB 2.0, USB 3.0, USB 3.2 Gen 1, USB4 | Dimensions (WxDxH) | 7.5 cm x 4.2 cm x 1.4 cm | Weight | 41 g | Colour | Space grey | System Requirements | Android, Google Chrome OS, Apple macOS 10.12, Apple macOS 10.13, Apple iPadOS, Apple macOS 10.11, Apple macOS 10.15, Apple macOS 11.0, Apple macOS 12, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Linux Kernel 4.11.x or later (LTS versions only) | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Processor | X Fresco Logic FL7102 / FL5001 |
Expansion / Connectivity | |
Interfaces | 2 x USB 3.2 Gen 1 Type A , 1 x USB 3.2 Gen 1 (power delivery) Type C pass-through , 1 x USB 3.2 Gen 1 Type C |
Power | |
Power Consumption Operational | 15 Watt |
Miscellaneous | |
Cables Included | 1 x USB-C cable - 30 cm |
Compliant Standards | Plug and Play, RoHS, WEEE, UASP (USB Attached SCSI Protocol), Thunderbolt 3, Thunderbolt 4 |
Software / System Requirements | |
OS Required | Android, Google Chrome OS, Apple macOS 10.12, Apple macOS 10.13, Apple iPadOS, Apple macOS 10.11, Apple macOS 10.15, Apple macOS 11.0, Apple macOS 12, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Linux Kernel 4.11.x or later (LTS versions only) |
Dimensions & Weight | |
Width | 7.5 cm |
Depth | 4.2 cm |
Height | 1.4 cm |
Weight | 41 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 14.2 cm |
Shipping Depth | 17.5 cm |
Shipping Height | 3 cm |
Shipping Weight | 94 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years , Technical support - assistance - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 5 - 85% RH |
Min Storage Temperature | -5 °C |
Max Storage Temperature | 70 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
