This USB Hub adds four USB-A 3.2 Gen 1 (5Gbps) ports to a USB-C enabled desktop or laptop computer. The USB Hub connects to a USB-C port on a computer, using the built-in 1ft. (30cm) host cable. The USB hub is backward compatible with USB 2.0 (480Mbps) devices, ensuring support for a wide range of modern and legacy USB peripherals (e.g., thumb drives, external HDDs/SSDs, HD cameras, mice, keyboards, webcams, and audio headsets). The USB hub is compact in size, facilitating portability when travelling.
Product Description | StarTech.com 4-Port USB-C Hub, USB 3.0 5Gbps, Bus Powered, USB Type-C to 4x USB-A Hub with Optional Auxiliary Power Input, Portable Desktop/Laptop USB Hub with 1ft (30cm) Attached Cable - USB Expansion Hub (5G4AB-USB-C-HUB) - hub - 4 ports | Device Type | Hub - 4 ports | Subtype | USB | Ports | 4 x USB 3.2 Gen 1 + 1 x micro-USB | Performance | Data transfer rate: 5 Gbps | Features | USB powered, plastic housing, USB overcurrent detection and prevention | Compliant Standards | USB 1.1, USB 2.0, USB 3.2 Gen 1, USB4 | Dimensions (WxDxH) | 5.4 cm x 42 cm x 1.6 cm | Weight | 82 g | Colour | Space grey | System Requirements | Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Processor | X VIA VL817 |
Expansion / Connectivity | |
Interfaces | 4 x USB 3.2 Gen 1 Type A , 1 x micro-USB input Type B |
Miscellaneous | |
Cables Included | 1 x USB-C cable - 30 cm |
Compliant Standards | Plug and Play, RoHS, WEEE, RCM, UASP (USB Attached SCSI Protocol), Thunderbolt 3, Thunderbolt 4 |
Software / System Requirements | |
OS Required | Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS |
Dimensions & Weight | |
Width | 5.4 cm |
Depth | 42 cm |
Height | 1.6 cm |
Weight | 82 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 14.7 cm |
Shipping Depth | 17 cm |
Shipping Height | 3 cm |
Shipping Weight | 133 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years , Technical support - assistance - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 0 - 95% |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 80 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
