This USB Hub adds four USB-A 3.2 Gen 1 (5Gbps) ports to a USB-C enabled desktop or laptop computer. The USB Hub connects to a USB-C port on a computer, using the built-in 1ft. (30cm) host cable. The USB hub is backward compatible with USB 2.0 (480Mbps) devices, ensuring support for a wide range of modern and legacy USB peripherals (e.g., thumb drives, external HDDs/SSDs, HD cameras, mice, keyboards, webcams, and audio headsets). The USB hub is compact in size, facilitating portability when travelling.
Product Description | StarTech.com 4-Port USB-C Hub, USB 3.0 5Gbps, Bus Powered, USB Type-C to 4x USB-A Hub with Optional Auxiliary Power Input, Portable Desktop/Laptop USB Hub with 1ft (30cm) Attached Cable - USB Expansion Hub (5G4AB-USB-C-HUB) - hub - 4 ports | Device Type | Hub - 4 ports | Subtype | USB | Ports | 4 x USB 3.2 Gen 1 + 1 x micro-USB | Performance | Data transfer rate: 5 Gbps | Features | USB powered, plastic housing, USB overcurrent detection and prevention | Compliant Standards | USB 1.1, USB 2.0, USB 3.2 Gen 1, USB4 | Dimensions (WxDxH) | 5.4 cm x 42 cm x 1.6 cm | Weight | 82 g | Colour | Space grey | System Requirements | Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Processor | X VIA VL817 |
Expansion / Connectivity | |
Interfaces | 4 x USB 3.2 Gen 1 Type A , 1 x micro-USB input Type B |
Miscellaneous | |
Cables Included | 1 x USB-C cable - 30 cm |
Compliant Standards | Plug and Play, RoHS, WEEE, RCM, UASP (USB Attached SCSI Protocol), Thunderbolt 3, Thunderbolt 4 |
Software / System Requirements | |
OS Required | Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS |
Dimensions & Weight | |
Width | 5.4 cm |
Depth | 42 cm |
Height | 1.6 cm |
Weight | 82 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 14.7 cm |
Shipping Depth | 17 cm |
Shipping Height | 3 cm |
Shipping Weight | 133 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years , Technical support - assistance - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 0 - 95% |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 80 °C |
