StarTech.com 4 Port USB C Hub 10Gbps
£159.21
27 in stock
Delivery:
Standard: 1-3 working days
Key features
  • INDUSTRIAL 4 PORT USB-C HUB: Expand the connectivity of a USB-C or USB-A computer by adding 2x USB Type-A & 2x USB Type-C ports; SuperSpeed 10Gbps USB 3.2/3.1 Gen 2 hub; 3.3 ft (1m) USB-C & USB-A host cables included (w/ screw-lock)
  • ESD SURGE PROTECTION: Featuring 15kV Air and 8kV Contact electrostatic discharge protection, this rugged metal-enclosed hub is suitable for harsh industrial/commercial environments
  • POWER & CHARGE: Self powered USB C hub w/ 36W power adapter & terminal block connector (7-24V DC inputs); Charging w/BC 1.2 for 30W total on all ports | Provides 12W (2.4A) on all ports up to a total 30W draw
  • INSTALLATION FLEXIBILITY: Mountable USB Type-C Hub with built-in ear mounting allows for wall/surface mounting; All USB-A & USB-C ports on hub feature screw-lock connectors to prevent accidental cable release
  • COMPATIBILITY: USB expansion hub is OS independent, supports Windows, macOS, Linux, iPadOS, Chrome OS, Android; Thunderbolt 3 & USB 3.0/2.0 compatible; For use in manufacturing, automation, labs, schools, IT; MTT for max bandwidth with mixed-speed devices
  • Type: USB
  • Ports: 4
  • Stock Status: In Stock
Product codes
Industrial USB Hub - Metal Housing - Built-in Mounting Hardware - Screw Locking Ports.
Product Description StarTech.com 4 Port USB C Hub 10Gbps, Metal Industrial USB-C Hub, 2x USB-C & 2x USB-A, ESD Surge Protection, USB-C or USB-A Host, Self-Powered, Mountable USB 3.1 Gen 2 Type-C Hub - Commercial/Rugged USB Hub - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 2 x USB 3.2 Gen 2 + 2 x USB-C 3.2 Gen 2
Features Screw lock, metal housing, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge)
Compliant Standards USB 2.0, USB 3.0, USB 3.1 Gen 1, USB 3.1 Gen 2, USB 3.2 Gen 2, USB 3.2 Gen 1, Battery Charging 1.2
Power AC 100-240 V
Dimensions (WxDxH) 5.96 cm x 15.2 cm x 2.35 cm
Weight 280 g
Colour Black
Localisation Australia, Japan, New Zealand, North America, United Kingdom, Europe
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£159.21
