StarTech.com 4-Port USB C Hub with On/Off
£36.64
17 in stock
Delivery:
Standard: 1-3 working days
  • Type: USB Hub
  • Interface: USB
  • Ports: 4
  • Form Factor: External
  • Stock Status: In Stock
Product codes
This portable USB-C hub gives you an easy way to add four USB 3.0 Type-A ports to your USB-C equipped laptop, tablet or smartphone, with individual power switches to conserve power. The USB-C to USB 3.0 hub plugs easily into your laptop's USB Type-C or Thunderbolt 3 port. Plus, it's bus-powered for easy portability.
Use your existing USB 3.0 devices such as flash drives, mouse, keyboard and external hard drives. The 4-port USB 3.0 hub converts your computer's USB-C port into four USB 3.0 (Type-A ports), and it's backward compatible with your older USB 2.0 devices. (USB 3.0 is also known as USB 3.1 Gen 1.)
Each USB port on the USB Type-C hub has its own power switch so you can turn off devices when they're not in use. That means you can better manage power consumption for your USB devices, without having to physically disconnect the device or cable.
With its compact, lightweight design, this USB hub is designed for portable use. The versatile USB-C to USB hub is bus-powered, which means it draws its power directly from your computer's USB-C port, with no need for an external power adapter. You can travel lighter with fewer cables to carry with you.
The 4-Port USB-C hub installs automatically once you connect it to your laptop, so you can be up and running in seconds.
Product Description StarTech.com 4 Port USB C Hub, USB-C to 4x USB 3.0 Type-A Ports with Individual On/Off Port Switches, SuperSpeed 5Gbps USB 3.1/3.2 Gen 1, USB Bus Powered, Portable, 10" Attached Cable - Windows/macOS/Linux (HB30C4AIB) - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 4 x USB 3.1 Gen 1
Features USB powered, on/off switches
Compliant Standards USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 1
Dimensions (WxDxH) 3.49 cm x 8.5 cm x 1.92 cm
Colour Black
System Requirements Apple MacOS, Linux, Microsoft Windows
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£36.64
