Turn a USB Type-C port on your laptop into four USB Type-A ports (5Gbps), plus power and charge your laptop. This compact USB 3.0 hub lets you add four USB-A ports to your laptop, with support for USB power delivery. This means that you can power and charge your laptop through its USB-C port while simultaneously powering the hub.
With its integrated USB Type-C cable and small-footprint design, this versatile hub offers a perfectly portable solution for connecting devices that require traditional USB Type-A ports to your USB-C or Thunderbolt 3 equipped computer.
With its compact and rugged design, you can take this portable USB 3.0 hub anywhere you go. Because it's so compact, it's easy to tuck into your laptop bag and only takes up a small amount of desk space when you connect it to your workstation. For portable applications, having the integrated host (USB-C) cable means one less thing to remember to carry with you.
This USB-C 3.0 hub supports USB Power Delivery 2.0, so instead of carrying multiple cables and power adapters, you can use your laptop's USB-C power adapter to power both your laptop and the hub. By using just a single power adapter instead of two, you can eliminate clutter and hassle when you work.
This USB hub is multi-platform compatible, which means it will work with a wide range of USB-C laptops that use a USB-C power adapter. It also works with a range of operating systems such as Windows, macOS, Linux and Chrome OS . It installs automatically once you connect it to your laptop, so you can be up and running in seconds.
Product Description | StarTech.com 4 Port USB C Hub with 4 USB Type-A Ports (USB 3.0 SuperSpeed 5Gbps), 60W Power Delivery Passthrough Charging, USB 3.1 Gen 1/USB 3.2 Gen 1 Laptop Hub Adapter, MacBook, Dell - Windows/macOS/Linux (HB30C4AFPD) - hub - 4 ports | Device Type | Hub - 4 ports | Subtype | USB | Ports | 4 x SuperSpeed USB 3.0 | Features | USB powered, USB Attached SCSI Protocol (UASP) | Compliant Standards | USB 1.1, USB 2.0, USB 3.0, USB 3.1 | Dimensions (WxDxH) | 4 cm x 9.3 cm x 1.1 cm | Weight | 40.5 g | Colour | Black | System Requirements | Apple MacOS, Linux, Microsoft Windows, Google Chrome OS | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Processor | X VIA VL812 |
Expansion / Connectivity | |
Interfaces | 4 x USB 3.0 output Type A , 1 x USB 3.0 input Type C |
Miscellaneous | |
Colour | Black |
Cables Included | 1 x SuperSpeed USB-C cable - 15 cm |
Compliant Standards | Plug and Play, FCC, RoHS, WEEE, USB Power Delivery 2.0 |
Software / System Requirements | |
OS Required | Apple MacOS, Linux, Microsoft Windows, Google Chrome OS |
Dimensions & Weight | |
Width | 4 cm |
Depth | 9.3 cm |
Height | 1.1 cm |
Weight | 40.5 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -10 °C |
Max Storage Temperature | 70 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
