StarTech.com 4-Port USBC Hub w/?PD 3.0- 10Gbps - 3x A & 1...
StarTech.com 4-Port USBC Hub w/?PD 3.0- 10Gbps - 3x A & 1x C?- 9.8" Host
£65.96
11 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Adds one USB-C and three USB-A ports to your Mac, Windows, Linux or other USB-C laptop
  • USB Type-C hub supports USB 3.1 Gen 2 data transfer rates up to 10Gbps
  • Compact, portable design with an extended attached host cable of 9.8" (25 cm)
  • Type: USB
  • Ports: 4
Product codes
Expand the connectivity of your USB-C laptop with this new generation USB-C Gen 2 hub offering 10Gbps supporting greater bandwidth to connected devices and faster data transfer speeds. This bus-powered 4-Port USB-C hub plugs into your laptop's USB Type-C or Thunderbolt 3 port, adding one USB-C port and three USB-A ports, while allowing charging of your laptop.
The USB-C hub can support Power Delivery (3.0) pass through, when using a USB-C power adapter, to charge your laptop, with 15W reserved to power the hub itself.
This compact, lightweight USB-Type-C hub is a convenient and portable addition to your laptop accessories. The USB-C cable is built-in, and hub is bus-powered, so it draws its power directly from your computer's USB-C port, with no external power required. That means fewer cables to carry with you when you travel. The hub can draw up to 15 Watts of power from the connected host and operating multiple bus powered devices at one time with the total available power dependent on the connected host.
The extended length attached cable of 9.8" (25 cm) provides more flexibility for longer reach connection requirements and plug-and-play installation.
With ports for both USB-C and USB-A peripherals, this hub is backwards compatible supporting both legacy and new USB devices. You can connect flash drives, video capture devices and external hard drives, with fast data transfer speeds of up to 10Gbps. This 4-port USB Type-C hub enhances your productivity, giving you the connections, you need while you work.
Product Description StarTech.com 4 Port USB C Hub (10Gbps) to 3x USB-A & 1x USB-C, 100W Power Delivery Passthrough Charging, Compact/Portable USB 3.1 Gen 2/USB 3.2 Gen 2 Type C Laptop Adapter, Works w/ TB3 - Windows/macOS/Linux - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 1 x USB-C + 3 x USB 3.1
Features USB powered
Compliant Standards USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, Power Delivery 3.0, USB 3.2 Gen 2
Dimensions (WxDxH) 31 cm x 20.7 cm x 3.8 cm
Weight 196 g
Colour Black, space grey
Designed For P/N: PEXUSB321C
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£65.96
