StarTech.com 4 Port VGA Video Audio Switch with RS232 control
£158.62
Select:
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
  • Type: Switch
  • Stock Status: In Stock
Product codes
This 4 Port VGA Video and Audio Switch lets you switch between four separate VGA signals, as well as the corresponding audio, for output to a single display or projector.
An ideal solution for situations where VGA and audio input ports are scarce, the VGA switch eliminates the hassle of having to swap out connections to your display and audio receiver, while letting you select the video source at the push of a button.
The VGA switch also features convenient remote switching capability, through either RS232 serial remote control or the included IR remote control - allowing you to switch between VGA input signals from a distance and in turn providing a convenient addition to presentation displays, trade shows, security environments and more.
Product Description StarTech.com 4 Port VGA Video Audio Switch with RS232 control - video/audio splitter - 4 ports
Device Type Video/audio splitter - 4 ports
Dimensions (WxDxH) 29.2 cm x 7.3 cm x 4.4 cm
Colour Black
Designed For P/N: SVA5M3NEUA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4 Port VG...
£158.62
