This 4-Port USB 3.2 Gen 1 (5Gbps) Hub adds four USB Type-A ports to a computer, with the added benefit of each port having an individual on/off switch. The USB hub is self-powered with an included power adapter. It connects to a USB-A, or USB-C port on a laptop or desktop computer.
Product Description | StarTech.com 4-Port Self-Powered USB-C Hub with Individual On/Off Switches, USB 3.0 5Gbps Expansion Hub w/Power Supply, Desktop/Laptop USB-C to USB-A Hub, 4x BC 1.2 (1.5A), USB Type C Hub - USB-C/A Host Cables (5G4AIBS-USB-HUB-EU) - hub - 4 ports | Device Type | Hub - 4 ports | Subtype | USB | Ports | 4 x USB 3.2 Gen 1 | Features | Self-powered mode, 4 on/off switches, aluminium housing, fast charging support, Charging Downstream Port (CDP), Dedicated Charging Port (DCP) | Compliant Standards | USB 1.1, USB 2.0, USB 3.0, USB 3.2 Gen 1, Battery Charging 1.2 | Power | AC 110-240 V | Dimensions (WxDxH) | 11.4 cm x 5.9 cm x 2.1 cm | Weight | 128 g | System Requirements | Apple MacOS, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS | Localisation | United Kingdom, Europe | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Processor | X VIA VL817 |
Status Indicators | Connection status |
Expansion / Connectivity | |
Interfaces | 4 x USB 3.2 Gen 1 Type A Battery Charging 1.2 , 1 x USB 3.2 Gen 1 Type B host |
Power | |
Power Device | External power adapter |
Power Provided | DC 12 V - 3 A |
Voltage Required | AC 110-240 V |
Power Consumption Operational | 36 Watt |
Miscellaneous | |
Cables Included | 1 x USB-A to USB-B cable - 1 m , 1 x USB-C to USB-B cable - 1 m |
MTBF | 50,000 hours |
Compliant Standards | Plug and Play, UASP (USB Attached SCSI Protocol) |
Software / System Requirements | |
OS Required | Apple MacOS, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS |
Dimensions & Weight | |
Width | 11.4 cm |
Depth | 5.9 cm |
Height | 2.1 cm |
Weight | 128 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 22.5 cm |
Shipping Depth | 17 cm |
Shipping Height | 7 cm |
Shipping Weight | 700 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years , Technical support - assistance - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% RH (non-condensing) |
Min Storage Temperature | -10 °C |
Max Storage Temperature | 70 °C |
