StarTech.com 4-to-1 HDMI Video Switch with Remote Control
£56.10
Select:
15 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Allows you to easily switch between 4 HDMI devices without having to unplug anything from your display
  • Converge A/V by StarTech.com offers a full line of Professional A/V products backed by a 1 year warranty and free lifetime technical support
  • Stock Status: In Stock
Product codes
This 4 port HDMI Switch lets you connect up to four HDMI output devices to a single HDMI input - eliminating the need to manually exchange cables to switch between high definition audio video sources.
The HDMI switch fully supports HDMI device connections, as well as display resolutions up to 1080p(HDTV) / 1920x1200(computer), ensuring a high quality audio and video experience. Suitable for long distance connections, the switch offers a signal enhancement feature that can be used with longer cable connections, boosting the HDMI signal for optimized quality.
The switch provides an economical solution for connecting multiple HDMI out devices (Blu-Ray players, DVD Players, etc.) to a single port on a high definition LCD/Plasma TV.
Product Description StarTech.com 4-to-1 HDMI Video Switch with Remote Control - video/audio switch - 4 ports
Device Type Video/audio switch - 4 ports
Subtype HDMI
Ports 4 x HDMI
Features HDCP compliant
Compliant Standards HDCP 1.1, DVI 1.0
Dimensions (WxDxH) 24 cm x 10.4 cm x 4.4 cm
Weight 1.25 kg
Colour Black
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4-to-1 HD...
£56.10
