Share up to four USB 3.0 devices between four different computers. This 4x4 USB 3.0 peripheral sharing switch lets you share four USB 3.0 peripheral devices between four different computers, providing a cost-effective way to create a more productive, space-efficient work area.
Save the expense of purchasing duplicate peripherals, by sharing devices (such as USB printers, portable hard drives, mouse and keyboard) with up to four computers. The USB switch also lets you avoid having to swap cables from one system to another, saving time and effort.
Enjoy fast data transfers to and from your shared peripheral devices. The USB switch supports USB 3.0 (up to 5Gbps), providing high-bandwidth support for devices like external hard drives and webcams. The USB 3.0 switch is also backward compatible with USB 2.0/1.1 and works with older devices.
The plug-and-play USB switch is easy to use, with no drivers or software required. It features a remote port selector that lets you switch peripheral devices from one computer to another with the press of a button. The LED indicates the active computer.
The switch's compact design takes up minimal desk space and it's USB-powered.
The 4-port USB switch can also be connected to a USB hub or docking station, to expand the number of shared devices.
Product Description | StarTech.com 4X4 USB 3.0 Peripheral Sharing Switch - For Mac / Windows / Linux - switch - 4 ports | Device Type | Switch - 4 ports | Subtype | USB | Ports | 8 x SuperSpeed USB 3.0 | Features | USB powered, plastic housing, over-current protection | Dimensions (WxDxH) | 9.4 cm x 9.4 cm x 2.6 cm | Weight | 130 g | Colour | Black | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Expansion / Connectivity | |
Interfaces | 4 x USB 3.0 Type A , 1 x USB 3.0 Type B , 1 x micro-USB (power only) Type B |
Miscellaneous | |
Colour | Black |
Cables Included | 2 x USB-A to USB-B cable - 1.2 m , 2 x USB-A to USB-B cable - 1.8 cm , 1 x remote port selector - 1.8 cm |
Dimensions & Weight | |
Width | 9.4 cm |
Depth | 9.4 cm |
Height | 2.6 cm |
Weight | 130 g |
Dimensions & Weight (Shipping) | |
Shipping Weight | 650 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 0 - 80% |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 60 °C |
Humidity Range Storage | 0 - 80% |
