StarTech.com 40 ft Coax High Resolution Monitor VGA Cable - H...
StarTech.com 40 ft Coax High Resolution Monitor VGA Cable - HD15 M/M
£26.06
Delivery:
Standard: 1-3 working days
  • Length: 12.2m
  • Stock Status: In Stock
Product codes
This 40-foot High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
Product Description StarTech.com 40 ft. (12.2 m) VGA to VGA Cable - HD15 Male to HD15 Male - Triple-Coaxial - High Quality - VGA Monitor Cable (MXT101MMHQ40) - VGA cable - 12.2 m
Type VGA cable
Technology Triple shielded twisted pair coaxial
Features Molded, ferrite bead
Length 12.2 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - male
Colour Black
Designed For P/N: CDP2VGA, CDP2VGAFC, DVI2VGAE, DVIVGAMF, DVIVGAMFBK, HD2VGAE2, HD2VGAMICRO
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 40 ft Coa...
£26.06
