StarTech.com 40 Pin Female IDE to SATA Adapter Converter
£13.27
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • A compact form factor to fit into almost any installation and no driver installation for true plug and play installation
  • Backed by a lifetime warranty and free lifetime technical support
  • Stock Status: In Stock
Product codes
Documents
Allows connection of a SATA device to an IDE motherboard or card.
This IDE to SATA adapter converts a 40-pin IDE connector to a SATA connector, allowing you to connect a 2.5in or 3.5in SATA (SATA, SATA II/SATA 300) drive to the motherboard in place of an IDE drive.
The IDE to SATA Adapter is suitable for installation in any computer case, as it is requires minimal space and does not impact airflow.
Product Description StarTech.com 40 Pin Female IDE to SATA Adapter Converter - Connect a SATA device to an IDE controller - IDE to SATA Converter (IDE2SAT25) - storage controller - ATA - SATA
Device Type Storage controller - internal
Bus Type SATA
Interface ATA
Data Transfer Rate 133 MBps
Supported Devices Hard drive
Channel Qty 1
System Requirements Microsoft Windows Vista / 2000 / XP
Dimensions (WxDxH) 3.2 cm x 8 cm x 0.9 cm
Weight 12 g
Designed For P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25X2, BRACKET425F
Resources
The following resources are available for the StarTech.com 40 Pin Female IDE to SATA Adapter Converter
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 40 Pin Fe...
£13.27
