StarTech.com 40-Pin IDE PATA to SATA Adapter Converter for HD...
StarTech.com 40-Pin IDE PATA to SATA Adapter Converter for HDD/SSD/ODD
£16.16
31 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by a StarTech.com 2 year warranty and free lifetime technical support
  • Blu-ray, DVD and CD-ROM drive compatibility with ODD (Optical Disk Drive) support, from an IDE host connection
  • Hassle-free installation, with no software CD required
  • Type: Adapter
  • Stock Status: In Stock
Product codes
Connect your SATA Hard Drive or Blu-ray/DVD/CD-ROM Drive to an IDE motherboard. The IDE2SAT240-pin IDE to SATA adapter enables you to connect a SATA I/II/III drive to an available IDE/ATA 33/66/100/133 motherboard port - a cost-effective solution that allows you to add newer SATA drives, and keep your existing motherboard.
The IDE/SATA adapter offers a cost-effective solution for bridging the gap between a newer 2.5"/3.5"/5.25" SATA drive and older IDE motherboard port. The IDE2SAT2 also features ODD (Optical Disk Drive) support, allowing you to a add Blu-ray, DVD, or CD-ROM drives to an older IDE motherboard.
Product Description StarTech.com 40-Pin IDE PATA to SATA Adapter Converter - storage controller - SATA 1.5Gb/s - Ultra ATA/133
Device Type Storage controller
Bus Type Ultra ATA/133
Interface SATA 1.5Gb/s
Data Transfer Rate 133 MBps
Supported Devices Hard drive, CD drive, DVD drive
Channel Qty 1
Max Storage Devices Qty 1
Dimensions (WxDxH) 2 cm x 7.55 cm x 2.3 cm
Weight 15 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 40-Pin ID...
£16.16
