StarTech.com 40x10mm Replacement Dual Ball Bearing Computer C...
StarTech.com 40x10mm Replacement Dual Ball Bearing Computer Case Fan with LP4
£6.08
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Type: Case Fan
  • Stock Status: In Stock
Product codes
Add additional chassis cooling with a 40mm ball bearing fan. This 40mmx10mm PC computer cooling fan is a perfect addition or replacement PC fan for maintaining suitable operating temperatures within your computer case. The PC fan can be powered through a simple LP4 connection to the PC power supply and offers a dual ball bearing design to ensure quiet, dependable operation.
Product Description StarTech.com 40x10mm Replacement Dual Ball Bearing Computer Case Fan w/ LP4 system fan kit
Product Type System fan kit
Fan Diameter 40 mm
Noise Level 23 dB
Weight 25 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 40x10mm R...
£6.08
