StarTech.com 430 Watt ATX12V 2.3 80 Plus Computer Power Suppl...
StarTech.com 430 Watt ATX12V 2.3 80 Plus Computer Power Supply w/ Active PFC
£53.96
Delivery:
Key features
  • Reduce operation cost and energy consumption with an 80 Plus certified power supply
  • Universal compatibility supporting EPS and ATX Intel/AMD motherboards
Product codes
Build or upgrade a computer system with an energy efficient and reliable 430 Watt ATX power supply. The ATX2PW430WH 430 Watt 80 Plus Power Supply offers an energy efficient replacement or upgrade for powering your desktop PC. Operating at a minimum of 80% efficiency between 20% and 100% load, 80 Plus power supplies deliver a significant improvement over standard-efficiency power supplies that helps reduce energy consumption and cost of operation.
This versatile power supply is equipped to support AMD or Intel CPU-based servers and workstations with a combined 20/24-pin motherboard connection, and an 8-pin EPS connector.
StarTech.com 430 Watt ATX12V 2.3 80 Plus Power Supply w/ Active PFC - power supply - 430 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V 2.92
80 PLUS Certification
80 PLUS
Input Voltage
AC 115/230 V
Output Voltage
+3.3, ±5, ±12 V
Power Capacity
430 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 4 pin ATX12V connector , 1 x 8 pin PCI Express power , 4 x 15 pin Serial ATA power , 3 x 4 PIN internal power
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 430 Watt...
£53.96
