StarTech.com 4K HDMI Audio Extractor
£62.59
Delivery:
Standard: 1-3 working days
Key features
  • Separate and send the audio from a 4K HDMI video signal to dedicated audio devices
  • Supports the latest HDMI 2.0 specifications and HDR video pass-through
  • Hassle-free connection with digital optical audio or Dual RCA audio devices
  • Stock Status: In Stock
Product codes
This 4K HDMI audio extractor lets you de-embed the audio from your HDMI video streams to create a distinct audio output that you can connect directly to a digital or analog audio device. Supporting HDMI 2.0 specifications, the de-embedder maintains 4K 60Hz resolutions to deliver a seamless video experience.
The HDMI sound splitter supports video resolutions up to 4K 60Hz (3840 x 2160) and high video bandwidth up to 18Gbps. It also supports High Dynamic Range (HDR) video pass-through, letting you enjoy lifelike images with incredible contrast, brightness and color, and greater luminosity compared to standard digital imaging.
Easily integrate HDMI 2.0 devices, such as your new 4K Blu-ray player, with your existing audio equipment or desktop speakers. The extractor isolates and extracts the audio signal from your HDMI cable and lets you output to digital optical audio or dual RCA audio devices. The integrated EDID management capabilities support 2-channel, 5.1-channel and pass-through audio modes.\
The HDCP compliant HDMI audio de-embedder is compatible with dual-RCA composite adapters, giving you the flexibility to integrate the audio from your HDMI source into 3.5 mm audio applications using MU6MMRCA, MU3MMRCA or MUFMRCA (sold separately).
The compact extractor features a small footprint that blends discreetly into your hardware setup, for a uniform look.
Product Description StarTech.com 4K HDMI Audio Extractor 4K 60Hz - HDR - Toslink Optical Audio - HDMI audio signal extractor
Product Type HDMI audio signal extractor
Package Content Power adapter, HDMI audio signal extractor, mounting screws, mounting brackets
Product Material Aluminium
Dimensions (WxDxH) 8 cm x 9 cm x 2.2 cm
Weight 320 g
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4K HDMI A...
£62.59
