StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable...
StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M
£19.09
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com lifetime warranty
  • Cost-effective solution for adding a standard DisplayPort connection to your Mini Displayport-equipped PC or Mac
  • Durably constructed, ensuring a long-term solution for DisplayPort to Mini DisplayPort connections
  • Length: 4m
  • Stock Status: In Stock
Product codes
Connect your Mini-DisplayPort-equipped computer to a standard DisplayPort monitor. The MDP2DPMM4M 4m Mini DisplayPort to DisplayPort Cable features a Mini DisplayPort (male) connector on one end, and a DisplayPort (male) connector on the other, enabling you to connect your Mini DisplayPort-equipped laptop or Mac family of products to a monitor or projector that uses a standard DisplayPort connection.
Product Description StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M - 4m Mini DisplayPort to DisplayPort - Mini DP to DP Cable (MDP2DPMM4M) - DisplayPort cable - 4 m
Type DisplayPort cable
Technology Shielded
Length 4 m
Connector Mini DisplayPort - male
Connector (Second End) DisplayPort - male
Compliant Standards RoHS
Colour Black
Designed For P/N: CDP2MDP, CDP2MDPFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP, HD2DP
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4m Mini D...
£19.09
