StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC
£30.80
Select:
Delivery:
Standard: 1-3 working days
Key features
  • Guaranteed reliability
  • Suitable for installations under restrictive building codes, with LSZH rating
  • Length: 4m
  • Colour: Yellow
  • Stock Status: In Stock
Product codes
Connect fiber network devices for high-speed transfers with LSZH rated cable. The SMFIBLCLC4 4m LC to LC Single-Mode Duplex Fiber Cable features 9/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex single-mode applications.
This LC-LC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire - an ideal solution for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 9/125 (OS1) Single-Mode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
Product Description StarTech.com 4m Fiber Optic Cable - Single-Mode Duplex 9/125 - LSZH - LC/LC - OS1 - LC to LC Fiber Patch Cable (SMFIBLCLC4) - patch cable - 4 m - yellow
Type Patch cable - OS1
Technology Fibre optic
Features Molded
Length 4 m
Core / Cladding Diameter 9 / 125 micron
Connector 2 x LC single-mode - male
Connector (Second End) 2 x LC single-mode - male
Colour Yellow
Designed For P/N: GLCEXSMDST, GLCLHSMDSTTA, GLCLXSMRGDST, GLCZXSMRGDST, JD119BST, MASFP1GBLX10, QSFP40GLR4S, QSFP40GLR4ST, QSFP40LR4ST, QSFP40SR4ST, SFP100BBXDST, SFP100BBXUST, SFP100BEXST, SFP100BLHST, SFP100BLXST, SFP100BZXST, SFP10GBBXDST, SFP10GBBXUST, SFP10GBERST, SFP10GBLRST, SFP10GBZRST, SFP1GELXST
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4m Single...
£30.80
