StarTech.com 4m USB 2.0 C Cable w/ PD (5A)
£17.38
27 in stock
Delivery:
Standard: 1-3 working days
  • Length: 4m
  • Stock Status: In Stock
Product codes
Power your USB Type-C devices over longer distances. This USB-C cable with USB Power Delivery lets you power USB Type-C devices from your USB-C laptop or charge your USB-C laptop from a USB-C wall charger.
With up to 5A (100W) of power output, you can use this USB Type-C cable to power and charge a USB-C laptop, such as your Apple MacBook or Chromebook Pixel, using a USB-C wall charger, car charger or power bank. Or, you can power your laptop from a USB-C docking station.
The 5A of power delivery lets you charge your mobile devices faster than with a regular USB-C 2.0 cable. The cable is perfect for people on the move - decrease your charge times and make sure your mobile devices are ready, whenever you need them, while you're on the road.
The non-standard 4-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, the connection to your mobile device will reach your computer or wall charger more comfortably.
The cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable and high-quality cable for all of your USB-C devices.
Product Description StarTech.com 4m USB C Cable w/ PD - 13ft USB Type C Cable - 5A Power Delivery - USB 2.0 USB-IF Certified - USB 2.0 Type-C Cable - 100W/5A (USB2C5C4M) - USB-C cable - 4 m
Type USB-C cable
Features Sync and charge
Length 4 m
Connector 24 pin USB-C - male
Connector (Second End) 24 pin USB-C - male
Rated Current 5 A
Compliant Standards USB 3.1
Designed For P/N: CDP2VGAUACP, CDP2VGAUCP, DKT30CHCPD, DKT30CHD, DKT30CHPD, DKT30CHPDW
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4m USB 2....
£17.38
