StarTech.com 4m USB 2.0 C to A Cable M/M
£22.03
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • USB-IF Certified
  • Offers 4 meters in cable length
  • Convenient, reversible USB-C connector makes every connection easy
  • Length: 4m
  • Stock Status: In Stock
Product codes
Connect your USB Type-C devices to your computer, over longer distances. This USB-C to USB-A cable makes it easy to charge and sync USB Type-C mobile devices using the USB-A port on your computer or a standard USB-A wall or car charger.
The non-standard 4-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, the connection to your mobile device will reach your computer or wall charger more comfortably.
The cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, ensuring a reliable, high-quality cable for all of your USB-C devices.
Product Description StarTech.com 4m 13ft USB C to A Cable - USB 2.0 USB-IF Certified - USB Type C to USB Type A Cable M/M - USB-C Charging Cable - USB A to C (USB2AC4M) - USB-C cable - USB-C to USB - 4 m
Type USB-C cable
Features Sync and charge
Length 4 m
Connector 24 pin USB-C - male
Connector (Second End) 4 pin USB Type A - male
Compliant Standards USB / USB 2.0
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£22.03
