StarTech.com 4Port SFP+ PCIe Network Card
£351.92
Delivery:
Standard: 1-3 working days
Key features
  • Add redundant connections in zero-downtime environments
  • Increase your network speed
  • Add scalable network connections to your server or workstation
  • Enhance your network capabilities
  • Wired / Wireless: Wired
  • Protocol: 10 Gigabit Ethernet
  • Compatibility: PC, Unix
  • Type: Network adapter
  • Stock Status: In Stock
Product codes
This SFP+ server network card delivers reliable, high-performance network connectivity, by adding four open SFP+ slots to your server or high-powered workstation. It provides an easy and cost-effective way to upgrade to a 10 Gigabit fiber network using SFP+ modules of your choice and gives you the flexibility to use either multimode or single-mode fiber.
Product Description StarTech.com Quad Port 10G SFP+ Network Card - Intel XL710 Open SFP+ Converged Adapter - PCIe 10 Gigabit Fiber Optic Server NIC - 10GbE - network adapter
Device Type Network adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express x8
Ports 10 Gigabit SFP+ x 4
Dimensions (WxDxH) 15 cm x 13.9 cm x 12 cm
Weight 129 g
Cabling Type Ethernet 10GBase-LR, Ethernet 10GBase-SR
Data Link Protocol 10 GigE
Data Transfer Rate 20 Gbps
Capacity Jumbo frame size: 9000
Processor Intel XL710
Compliant Standards IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae
Colour Black
System Requirements Microsoft Windows Server 2008 R2 (64-bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 2.6.24 - 4.11.x (64-bit) LTS versions, Microsoft Windows Server 2019 (64-bit)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4Port SFP...
£351.92
