This SFP+ server network card delivers reliable, high-performance network connectivity, by adding four open SFP+ slots to your server or high-powered workstation. It provides an easy and cost-effective way to upgrade to a 10 Gigabit fiber network using SFP+ modules of your choice and gives you the flexibility to use either multimode or single-mode fiber.
Product Description | StarTech.com Quad-Port SFP+ Server Network Card - PCI Express - Intel XL710 Chip - network adapter | Device Type | Network adapter | Form Factor | Plug-in card | Interface (Bus) Type | PCI Express x8 | Ports | 10 Gigabit SFP+ x 4 | Dimensions (WxDxH) | 15 cm x 13.9 cm x 12 cm | Weight | 129 g | Cabling Type | Ethernet 10GBase-LR, Ethernet 10GBase-SR | Data Link Protocol | 10 GigE | Data Transfer Rate | 20 Gbps | Capacity | Jumbo frame size: 9000 | Processor | XL710 - Intel | Compliant Standards | IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae | Colour | Black | System Requirements | Microsoft Windows Server 2008 R2 (64-bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 2.6.24 - 4.11.x (64-bit) LTS versions, Microsoft Windows Server 2019 (64-bit) | Manufacturer Warranty | 2-year warranty |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | 10 Gigabit Ethernet |
Features | Full duplex capability, Jumbo Frames support |
Processor / Memory | |
Expansion / Connectivity | |
Interfaces | 4 x 10GBase-LR - SFP+ |
Miscellaneous | |
Compliant Standards | FCC, RoHS, WEEE, RCM |
Colour | Black |
Software / System Requirements | |
OS Required | Microsoft Windows Server 2008 R2 (64-bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 2.6.24 - 4.11.x (64-bit) LTS versions, Microsoft Windows Server 2019 (64-bit) |
Dimensions & Weight | |
Width | 15 cm |
Depth | 13.9 cm |
Height | 12 cm |
Weight | 129 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 20 - 80% |
