Add four USB 2.0 ports to your USB Type-C laptop with this portable hub. This portable USB hub expands your laptop or desktop connectivity by adding four USB 2.0 (Type-A) ports through a single USB Type-C or Thunderbolt 3 port. And, because it's USB bus-powered, you don't need to connect an external power adapter, which makes travel more convenient and workstations less cluttered.
With its compact and lightweight construction, this 4-port USB hub is designed for mobility. You can easily tuck it into your laptop bag when you're traveling, which makes it easy to expand your connection options almost anywhere you need to. It's perfect for connecting common USB devices such as a mouse, keyboard, or flash drive, right when you need them.
The hub takes up minimal desk space and fits perfectly in hot-desk or BYOD environments.
This versatile USB-C hub is bus-powered, which means it draws its power directly from your computer's USB-C port. This means there are fewer cables to carry with you when you travel because it doesn't need an external power adapter.
This USB 2.0 hub will work with a wide range of computers because it requires no additional software or drivers. It installs automatically when you connect it to your laptop or desktop, so you can be up and running quickly. It also works with a range of operating systems such as Windows, macOS, Linux and Chrome OS, so it's multi-platform compatible.
Product Description | StarTech.com 4-Port USB-C Hub - USB-C to 4x USB-A Hub Adapter - Mini USB 2.0 Hub - Bus-powered USB Type-C Port Expander (ST4200MINIC) - hub - 4 ports | Device Type | Hub - 4 ports | Subtype | USB | Ports | 4 x USB 2.0 | Features | USB powered, plastic housing | Compliant Standards | USB 1.1, USB 2.0 | Dimensions (WxDxH) | 8 cm x 17.5 cm x 1.45 cm | Weight | 99 g | Colour | Black | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Expansion / Connectivity | |
Interfaces | 4 x USB 2.0 Type A , 1 x USB 3.0 Type C |
Miscellaneous | |
Colour | Black |
Cables Included | 1 x SuperSpeed USB-C cable |
Compliant Standards | FCC, RoHS, WEEE, RCM |
Dimensions & Weight | |
Width | 8 cm |
Depth | 17.5 cm |
Height | 1.45 cm |
Weight | 99 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 5 - 90% (non-condensing) |
Min Storage Temperature | -10 °C |
Max Storage Temperature | 70 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
