StarTech.com 4x 2.5" SSD/HDD Mount Bracket
£21.38
11 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Install four 2.5" solid-state drives or hard drives into two 5.25" front bays, to add storage to a desktop computer or server. Increase the performance and data storage capacity of your desktop computer or enhance your server room storage, with this 4-drive mounting bracket kit for 2.5" solid-state drives or hard drives.
This drive-mounting bracket lets you add four 2.5" SSDs or HDDs into two 5.25" front bays of your computer or server, allowing you to enhance your data storage capacity. The mounting brackets supports a wide range of 2.5" SSDs/HDDs from 5 to 15 mm in height.
A large built-in fan keeps air moving to dissipate heat build-up, and ensure optimum operating temperatures. Protecting against excessive heat build-up maximizes the life of your drives. The fan also features a dust filter making the mounting bracket ideal for industrial or corporate environments.
Engineered with steel framing, the mounting bracket is designed for dependable performance and durability.
Product Description StarTech.com 4x 2.5in SSD/HDD Mounting Bracket with Fan - Desktop or Server - storage bay adapter
Device Type Storage bay adapter
Supported Form Factor 5.25" to 2.5"
Expansion Bays 4 x internal - 2.5"
Compatible Bay 2 5.25"
Designed For P/N: M2E4SFF8643, PEX4SFF8643
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4x 2.5" S...
£21.38
