StarTech.com 4x M.2 PCIe to TB3 Enclosure
£413.25
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • HIGH PERFORMANCE M.2 STORAGE VIA THUNDERBOLT 3 : Turn up to 4 PCIe 80mm M.2 SSDs (M-Key) into an external TB3 storage solution; Data transfer speeds up to 40Gbps; Downstream TB3 port; DisplayPort video output; Vented metal enclosure w/thermal pads & fan
  • MAXIMIZE DRIVE SPEED: Connect up to four M.2 PCIe NVMe and/or AHCI drives with an 8Gbps PCIe lane dedicated to each SSD; Supports software RAID with storage management systems like Storage Spaces (Microsoft) , RAID Assistant (macOS), mdraid/mdadm (Linux)
  • FLEXIBLE PORT OPTIONS: DisplayPort output to connect to a display with resolutions up to 4K 60Hz; Downstream TB3 port to daisy chain additional TB3 devices or a compatible TB3 display (up to 5K 60Hz); Connected devices share bandwidth with connected SSDs
  • THUNDERBOLT 3 CERTIFIED: Works w/TB3 & TB4 host devices like MacBook Pro 16/13/Air (Dual displays on Mac w/Intel & M1 Pro/Max Processor; Dual display not supported on M1 Mac), Lenovo ThinkPad X1 Carbon/T Series, Dell XPS/Latitude/Precision & HP EliteBook
  • POWER ADAPTER & THUNDERBOLT 3 CABLE INCLUDED: Self powered with an included 72W EPS power supply that powers the enclosure, the connected drives and provides 15W to TB3 port; Includes 2.3 ft (70cm) TB3 certified passive cable; NOT COMPATIBLE WITH SATA SSD
  • Type: Storage enclosure
  • HD Size: M.2
Product codes
This Thunderbolt 3 to 4x M.2 PCIe SSD enclosure enables you to turn four M-Key PCI-Express based M.2 NVMe or AHCI solid state drives (SSDs) into a high-performance external storage solution. The SSD enclosure is self-powered with an included 72W EPS power supply that powers the enclosure, the connected drives, and provides up to 15W of power to any downstream Thunderbolt 3 devices. A 2.3 ft. (70 cm) Thunderbolt 3 Certified host cable is also included, to connect the enclosure to your computer.
Product Description StarTech.com 4 Bay Thunderbolt 3 NVMe Enclosure, For M.2 NVMe Solid State Drives, 1x DisplayPort Video & 2x TB3 Downstream Ports, Up to 40Gbps, 72W Power Supply - 4 Bay M.2 SSD External Hard Drive Enclosure (M2E4BTB3) - storage enclosure - M.2 NVMe Card / PCIe (NVMe) - Thunderbolt 3
Device Type Storage enclosure - external
Bus Type Thunderbolt 3
Colour Black
Localisation Australia, Japan, New Zealand, North Africa, United Kingdom, Europe
Expansion Bays 4 x internal - M.2 NGFF 2280
Hard Drive Form Factor Compatibility M.2
Interface M.2 NVMe Card / PCIe (NVMe)
Data Transfer Rate 40 GBps
Supported Devices Solid state drive
Max Storage Devices Qty 4
Power Source USB bus
Power AC 110-120 V
Dimensions (WxDxH) 16 cm x 12 cm x 2 cm
Weight 610 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£413.25
