StarTech.com 4x M.2 to SATA 3.5in adapter
£41.61
Delivery:
Standard: 1-3 working days
  • Type: Storage controller
  • HD Size: M.2
  • Stock Status: In Stock
Product codes
Enhance your system by mounting four M.2 (NGFF) SATA-based SSDs into one 3.5" drive bay. Here's an easy way to increase the speed, capacity and data security of your desktop computer or server. This four-drive M.2 SATA adapter and mounting bracket lets you add up to four M.2 solid-state drives in the same space as a single 3.5" SATA drive.
The M.2 adapter increases overall storage potential by installing four M.2 NGFF (Next Generation Form Factor) SSDs in a standard 3.5" drive bay. Utilize the full potential of your SATA III controller with an M.2 SSD, reducing data transfer bottlenecks and giving you file transfer rates of up to 6Gbps.
Create a high-performance RAID solution using four M.2 SSDs with your RAID controller to increase the volume capacity of your drive array and add redundancy to protect your data against drive failure. You can combine all four drives together to appear as one, to store larger files such as digital media and access them at faster speeds.
The adapter ensures easy and versatile use. It is designed to support a wide range of M.2 NGFF SSDs, including 2230, 2242, 2260, 2280 and 22110 drive sizes. It's also compatible with Windows, Mac, and Linux systems without having to install additional drivers or software.
Product Description StarTech.com 4x M.2 SSD to 3.5in SATA HDD Adapter - storage controller - SATA 6Gb/s - SATA 6Gb/s
Device Type Storage controller - internal
Bus Type SATA 6Gb/s
Hard Drive Form Factor Compatibility M.2
Interface SATA 6Gb/s
Data Transfer Rate 6 Gbit/s
Supported Devices Solid state drive
Max Storage Devices Qty 4
Dimensions (WxDxH) 10 cm x 13.9 cm x 3.4 cm
Weight 226 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4x M.2 to...
£41.61
