StarTech.com 4x SATA Power Splitter Adapter Cable
£5.95
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com lifetime warranty
  • Easy to use and install
  • Offers maximum system expandability without having to upgrade a computer power supply for the sake of SATA (power) connections
  • Length: 40cm
  • Stock Status: In Stock
Product codes
Add three extra SATA power outlets to your Power Supply. The PYO4SATA SATA power splitter cable (1-to-4) features a SATA male power connector that connects to a single computer power supply SATA connector, and breaks out into four SATA female power connectors.
The SATA power splitter cable overcomes the limit of the number of SATA drives that can be installed in the system, based on available PSU power connections, and eliminates the cost of having to upgrade the power supply to accommodate additional SATA drives.
Product Description StarTech.com 15.7 in (400 mm) SATA Power Splitter Adapter Cable - M/F - 4x Serial ATA Power Cable Splitter (PYO4SATA) - power splitter - 40 cm
Type Power splitter
Length 40 cm
Connector 15 pin Serial ATA power - male
Connector (Second End) 4 x 15 pin Serial ATA power - female
Colour Black
Designed For P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25X2, BRACKET425F, HSB2535SATBK, PEXUSB311AC3, S251BU31REM, SATBP125VP, SATSASBP425
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4x SATA P...
£5.95
